Scorpa Factory
shercosi
If you put the 16 Scorpa and Sherco side by side there are some significant differences. Marzocchi 40mm forks v Tech 39mm forks, frame has different extrusions around radiator and headstock, cable routing is different, tank is different, Michelin X11 v Dunlop D803GP and the list goes on
  On 7/18/2016 at 9:59 AM, nigel dabster said:
Thank you for your reply, but why is parts i c a good thing for these two makes?
Because it breads consistancy and helps a company identify weak links. I ts hard enough to be unique in this world with out repeating mistakes. Its also easier to make money when you order in bulk. Two companies using the same powertrain.... Its a no brainer.
If honda puts the same shift lever or oil pump on every bike montesa wins...
I use yz125 shift levers on scorpas...
--biff
