Frame Trim
badger360
How do you keep the right hand side one on as mine keeps falling off (pushed off with clutch hose/cable) on right hand turns ????
       Maybe i'm doing something wrong ???? But the little ears that sit behind the frame aren't strong enough for the hose/cable push and just comes off !
Check to see if the clutch hose runs up over the frame tube directly in front of the top of the radiator, between the two outer frame tubes. You can also cable tie the hose to the square section piece of frame at the headstock, though you shouldn't need to.
Also, check if you have the correct plastic piece in the right spot, there are "right" and "left" plastic pieces, the photo at the beginning of this thread shows the plastic piece correctly, the clutch hose routing is shown correctly also.
Bye, PeterB.
