Sherco 125 Fork Oil
stpauls
Early sherco but basically same to replace your oil without doing the seals .
.http://www.lewisportusa.com/manuals/sherc_11-21-09/sherco_fork_seal_replacement-1.pdf
NNNNNoooooooooo! It is not the same on the Tech forks! They are set by levels.
The right side has the damper unit. Here is the procedure: http://www.shercousa.com/pdfs/Sherco_Fork_Oil_Change.pdf
  • 1 year later...
Getting round to replacing the fork seals in my 2014 Sherco ST 125.
Questions:
1.  The right fork leg is refilled to within 55mm of the top of the fork tube.  Is that with the spring and rod in or out? (Not done this leg yet).
2.  What about the left fork leg?  Spring in or out?  Oil level 55mm as well?
Thanks in anticipation.
Questions:
Anytime you see a level quoted it will be with the fork compressed & no spring, rod should be extended as well
