lotus54 Posted February 24, 2017 Author Report Share Posted February 24, 2017 (edited) I put the 'O' rings on the outside of the Dogbone, they have a small chamfer for them to fit into (well, I assumed that was what it was for, otherwise they crush) I added a small shim (washer) between the bold and centre pin- ONLY enough to keep a slight clearance for all the pieces to keep moving when tightened quite firmly. I found locktite doesn't always hold well- especially where a lot of grease is (perhaps) already around and where the zerk could get it and moved. So far this has worked well for me. Perhaps your setup won't need that- a test fit before lubing would probably give a good idea. Does this make it more lucid? Edited February 24, 2017 by lotus54 Quote Link to comment Share on other sites More sharing options...
jsp Posted February 24, 2017 Report Share Posted February 24, 2017 yes that's great thanks, mine came with o rings fitted on both sides of the dogbones which I have managed to get on and in, but like you say you cant see if they have been crushed or not. I did also get a full new spare set in the kit Quote Link to comment Share on other sites More sharing options...
lotus54 Posted February 24, 2017 Author Report Share Posted February 24, 2017 Interesting. But not the 90° Zerk? They do know about that issue. perhaps they ve changd things a bit so O-rings fit in both places? Or maybe just extras? or I put mine in the wrong place... Quote Link to comment Share on other sites More sharing options...
jsp Posted February 27, 2017 Report Share Posted February 27, 2017 (edited) mine came with all the o rings in place as per my drawing and then a bag with the spares in, the 90 deg zerk did come fitted but to the front shaft up behind the bash plate so I've moved it to the middle bolt, but I've not had time to finnsh building it back up so I'm hoping once I get it all back together there will be some clearance for the zerk in the middle bolt Edited February 27, 2017 by jsp Quote Link to comment Share on other sites More sharing options...
worldtrialchamp Posted March 22, 2017 Report Share Posted March 22, 2017 JSP where can I buy one? Quote Link to comment Share on other sites More sharing options...
jsp Posted March 23, 2017 Report Share Posted March 23, 2017 contact Dominik on the email below and he will sort you out info@tpczech.com Quote Link to comment Share on other sites More sharing options...
