Rear Sprocket Plastic Fin.
trial bike
  On 4/5/2016 at 8:12 PM, trial bike said:
Does anyone know what material these things are made of?
Mine is about 3mm thick on my 4rt.
I was thinking of using 3mm PTFE sheet, readily available on a well known auction site. Any good?
What do you think?
I think it's (HD) polyethylene but PTFE should be fine.
I don't think PTFE would be strong enough. The ones I've made for my race bikes have either been PP, nylon 66 or carbon fibre sheet cut to suit, but that's mainly because I could get off cuts of them from work.
In reality anything will do the job but if it's likely to get knocked a bit it's needs to be able to give a bit without deforming permenantly. Personally for a trials bike I would try PP or nylon 66.
Edited by smokey125
You're right about PTFE not being the right material for the job, it's okay for a chain slider but isn't flexible enough to use as a shark fin, is more likely to snap the mounts off swingarm than flex
Just received a sheet of polypropylene, 3mm thick, ordered on line for less than a couple of quid, feels just like the original.
Cut out and shaped up a new fin tonight with enough spare for three more.
Fitted.
Perfect.
Thanks for the advice folks.
