303 Kickstarter Shaft
colly440
Hi, The cases have to be split, to change kick starter shaft. Shaft length can vary, so maybe better to strip first, for shaft comparison, also later shafts, were modified, to be without 'o' ring groove, as this was a weak point for shaft breakage. By 303 production, this modification may be done, still has an 'o' ring, but case chanfered to except 'o' ring on a plain shaft.
Edited by ask greeves
