katana Posted April 12, 2016 Report Share Posted April 12, 2016 Hi All I am trying to track down a fuel leak from the tank area. How does the little plastic tank cover get removed? I have tried prying it off, but am worried about breaking it. Cheers Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 12, 2016 Report Share Posted April 12, 2016 The little black circle just pops out from the front, but could break the tab due to age. Sounds like a cracked frame. Had a 2002 with several. Quote Link to comment Share on other sites More sharing options...
katana Posted April 12, 2016 Author Report Share Posted April 12, 2016 The little black circle just pops out from the front, but could break the tab due to age. Sounds like a cracked frame. Had a 2002 with several. Thank you! Quote Link to comment Share on other sites More sharing options...
nh014 Posted April 12, 2016 Report Share Posted April 12, 2016 The tank cover is secured by an o-ring, which is set in a grove below the inlet threads. Remove the o-ring and the cover lifts off. Quote Link to comment Share on other sites More sharing options...
katana Posted April 18, 2016 Author Report Share Posted April 18, 2016 The tank cover is secured by an o-ring, which is set in a grove below the inlet threads. Remove the o-ring and the cover lifts off. Thanks, that is what I was missing. Quote Link to comment Share on other sites More sharing options...
