Petrol Generator For Ktm Freeride E
pmski
Looking for advice on what petrol generator will power the charger for my Freeride E. I know it's not a trials bike but there is so much knowledge on here regarding E bikes.
So I want to take the bike to my local MX/Enduro bike park, they don't have electricity so I can't recharge between rides. I can easily get 60 mins+ continuous ride time when I am not gassing it MX style so my plan is ride for a hour, have lunch and recharge the bike, then ride for another hour, and repeat.
The charger needs 13 A steady output to fast charge, and 10A steady for normal charging.
I found this article that talks about charging the battery with a petrol generator on the KTM blog, so it's doable.
Had a look at generators, would this be suitable - its the 13/10A steady output that I am not sure about as it doesn't specify that in the specifications.
Any advice on what type of generator I should consider greatly appreciated.
you would be better off looking for a low voltage DC generator to charge the battery directly instead of using the 240v mains charger... what voltage is the battery on the ktm? i.e what is the voltage output of your charger ?
The battery needs the charger to manage the charging process - can't direct charge.
Don't know what voltage the battery is, but found this which may help?
Electric motor Permanent magnet synchronous motor
in a disc armature design
Rated output 7.5 kW (10.1 hp)
Max. power 22 kW (30 hp)
Traction battery Lithium-ion (easily removed)
Rated voltage 300 V
Wow is the battery really 300v !! Im very supprised at that as its a off road bike. Scape the idea about a direct dc charger as you will still need to boost even 240v even higher
The bike is fast, I mean proper angry fast when it's on power mode 3 so I would assume this is correct.
So if I want a generator that will output 13A consistently at 230v what would you recommend?
The Wolf generator is lower output than the Clarke generator in your 1st part of this thread, Be careful with stated outputs of generators from different manufacturers. They sometimes advertise the peak output instead of the continuous output, which is the max output it can cope with all day long. Peak output drawn for too long may damage the generator`or cause annoying tripping of its overload protection.
