Apico Lanyard Fitting . . .
lockie28
It's just a case of detaching the two wires from your existing engine kill switch from where they join the wiring loom, and connecting the two wires from the lanyard to the same two wires on the loom. It doesn't matter which way round they go, as the lanyard simply closes a circuit, shorting the live feed from the coil to earth. You can use crimp connectors or solder to join the wires.
  • Like 2
