baldilocks Posted April 22, 2016 Report Share Posted April 22, 2016 Rubber boot isn't the right term, it's called a diaphragm I think, takes up the free space below the master cylinder cap. Anyway this part will react badly with dot 4 and deform. I changed to dot 4 as I already had a large dot 4 master cylinder. The large cylinder made the clutch action softer. I don't think that the dot 4 made any difference Quote Link to comment Share on other sites More sharing options...
heffergm Posted April 22, 2016 Report Share Posted April 22, 2016 The fluid is going to have zero effect in changing the mechanical advantage (the force required to pull the clutch). My GG uses the usual mineral oil... it's got the lightest clutch pull I've ever felt in my life, and I haven't felt it slip. I have no idea what Stu did to it, but it's pretty sweet... Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 23, 2016 Report Share Posted April 23, 2016 Actually heffergm, ask about the original Jack. He had the first light spring made for the Pro clutch. Quote Link to comment Share on other sites More sharing options...
lian Posted April 23, 2016 Author Report Share Posted April 23, 2016 So, can anybody recall how look his clutch under top-hat? (My post #15). Thanks. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 24, 2016 Report Share Posted April 24, 2016 In my opinion you dont need it. It was not on mine (new), now I got a s3 one which only has O rings. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted May 16, 2016 Report Share Posted May 16, 2016 Lian did you solve your problem? Quote Link to comment Share on other sites More sharing options...
smarty156 Posted November 6, 2016 Report Share Posted November 6, 2016 I'd like to know if he solved the problem too as I have a similar problem. Quote Link to comment Share on other sites More sharing options...
Sectioned again Posted July 30, 2019 Report Share Posted July 30, 2019 I have a 2007 txt 280 and my brother has a 2010 txt 300. I only mention this as it is easy for me to compare one against the other and my problem is with the 280. I have the same issue with clutch slipping as Liam describes, and have been through all the same procedures as him trying to resolve the cause, . Did Liam ever resolve his issue with a new pressure ring? It feels like the clutch does not engage quickly, when I pull the lever it feels like there is a tiny delay when released. The slip is only very slight, but having put brand new steels and fibres in (DP) it is exactly the same. Should I suspect the master cyclinder? Has anyone had this problem as resolved it? Quote Link to comment Share on other sites More sharing options...
sectionone Posted July 30, 2019 Report Share Posted July 30, 2019 I have a 2007 txt 250 that I bought almost new. This year the clutch seemed slow and when I rode a different bike it was really apparent. There is a fine line between having the clutch pack too thick (stiff pull) or too thin (soft pull, slow clutch). I bought one of these and my clutch is snappy again. https://www.splatshop.co.uk/xiu-rdi-adjustable-spring-clutch-support-plate.html Quote Link to comment Share on other sites More sharing options...
2stroke4stroke Posted July 30, 2019 Report Share Posted July 30, 2019 Looks like what should be a standard fitment given the messing about that seems to be needed with these clutches. Quote Link to comment Share on other sites More sharing options...
Sectioned again Posted July 31, 2019 Report Share Posted July 31, 2019 Yes, its lucky for me that I can compare from the two gg's here. There is a lot of information here, with contradictions on the best oil, pressure plate going flat, I ordered another one but I don't think it is that. The previous owner put a new clutch in it as I made that a condition of its purchase, so he has been through all sorts trying to suss it out. I am all you-tubed up and beginning to suspect the master. I have a new set of plates and steels to go in and they are slightly thinner than the current set, It is a lot of messing about I have the correct measurement for pack and it slips when dumping the clutch in any gear, then slowly bites to a stall, so baffling. Anyway, will persevere until I get it sorted out. Quote Link to comment Share on other sites More sharing options...
Sectioned again Posted July 31, 2019 Report Share Posted July 31, 2019 17 hours ago, sectionone said: I have a 2007 txt 250 that I bought almost new. This year the clutch seemed slow and when I rode a different bike it was really apparent. There is a fine line between having the clutch pack too thick (stiff pull) or too thin (soft pull, slow clutch). I bought one of these and my clutch is snappy again. https://www.splatshop.co.uk/xiu-rdi-adjustable-spring-clutch-support-plate.html So I have just ordered one of these as well, thanks for your input .oh, and I thought I was being SOOOO individual with my user name, ha ha Quote Link to comment Share on other sites More sharing options...
