jfc Posted April 23, 2016 Report Share Posted April 23, 2016 The Airbox fitting is made more awkward by the lug that protrudes into the frame at the lower right hand side of the Airbox, what is this lug for (can't seem to see that it does anything)? Has anyone cut it off to make refit even more easy than standard? Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 23, 2016 Report Share Posted April 23, 2016 Sounds like you are missing the exhaust guard that was mounted to it. Quote Link to comment Share on other sites More sharing options...
jfc Posted April 23, 2016 Author Report Share Posted April 23, 2016 (edited) It's still as it was from new it's a 2015, it is part of the exhaust gaurd! Edited April 23, 2016 by jfc Quote Link to comment Share on other sites More sharing options...
jfc Posted April 23, 2016 Author Report Share Posted April 23, 2016 Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 23, 2016 Report Share Posted April 23, 2016 (edited) I would leave it alone. That tab helps to keep it in place from your boots tugging on it. Edited April 23, 2016 by lineaway Quote Link to comment Share on other sites More sharing options...
heffergm Posted April 23, 2016 Report Share Posted April 23, 2016 I agree that thing is pretty annoying. I wouldn't worry of you decide to hack it off. Mine will probably break off at some point while I'm putting the air box back on. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted April 24, 2016 Report Share Posted April 24, 2016 Before cutting check out the price of a new one 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 24, 2016 Report Share Posted April 24, 2016 That piece has always been on the Pro. I`ve installed the air box hundreds of times, never even noticed it much till re-jetting my bike yesterday. 1 Quote Link to comment Share on other sites More sharing options...
anotherfive Posted April 25, 2016 Report Share Posted April 25, 2016 I also find it annoying. Perhaps cut half of it off to ease reassembly. I thought it might be there for maintenance so that you don't have to screw everything back together before testing. 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 26, 2016 Report Share Posted April 26, 2016 It`s there to hold it in place. Without it you could rip it out of place with your boots. It won`t happen the first time, but over a period of time it will start sticking out. If you don`t ride much or very hard go ahead and cut it off. It`s cheap until you break the air box plastics. 1 Quote Link to comment Share on other sites More sharing options...
anotherfive Posted October 3, 2016 Report Share Posted October 3, 2016 On second Gas Gas now and have again cut the tab off, no issues to report apart from much easier to refit after carb work. Quote Link to comment Share on other sites More sharing options...
