mickthepieman Posted April 24, 2016 Report Share Posted April 24, 2016 I took my bike out this morning for a spin and when I got back home I noticed a small amount of black oil had dripped from the exhaust and cylinder, any ideas, this is my first 2 stroke bike. Thanks Mick Quote Link to comment Share on other sites More sharing options...
spen Posted April 24, 2016 Report Share Posted April 24, 2016 Normal....... 1 Quote Link to comment Share on other sites More sharing options...
mickthepieman Posted April 24, 2016 Author Report Share Posted April 24, 2016 Cheers. 1 Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted April 24, 2016 Report Share Posted April 24, 2016 You could make sure the exhaust is clamped to the cylinder nice and tight. Quote Link to comment Share on other sites More sharing options...
bondy Posted April 24, 2016 Report Share Posted April 24, 2016 yes as above tighten the 4 nuts in a criss cross so it gets a equal tocque there should be no oil comming from Exhaust or cylinder head if there is oil comming from cylinder head try tightening the head bolts to the tocque setting you will need tobtake the Exhaust off to get to the head bolts. or may be the head gasket need changing if it as 1 Quote Link to comment Share on other sites More sharing options...
twinnshock Posted April 24, 2016 Report Share Posted April 24, 2016 Not sure what model you have. If 4 bolts Bondy's advice is good. If earlier the exhaust is secured with a threaded ring. These are difficult to seal completely and black oil/residue seepage is normal. I worry more when it does not leak. Easily cleaned up. Stuart 2 Quote Link to comment Share on other sites More sharing options...
bondy Posted April 24, 2016 Report Share Posted April 24, 2016 we need to know what model it is???? Quote Link to comment Share on other sites More sharing options...
mickthepieman Posted April 25, 2016 Author Report Share Posted April 25, 2016 yes the exhaust is secured with a threaded ring. model 80 t 250 engine number M8000630 thanks for all you comments. Mick Quote Link to comment Share on other sites More sharing options...
bondy Posted April 25, 2016 Report Share Posted April 25, 2016 there should be a copper ring gasket have you checked if theres 1 there or may need replaceing? i have a ossa with the same typ off Exhaust with a screw ring.. Quote Link to comment Share on other sites More sharing options...
