anotherfive Posted April 26, 2016 Report Share Posted April 26, 2016 Might have a slight weep on the m cyl but its part of the formula set up. No name on cyl so are they interchangeable? Seen a new one for £60 rather than do seals piston etc.Any help appreciated. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 27, 2016 Report Share Posted April 27, 2016 I would say yes, why not, but I havent tried. Couple of questions: Are the mounting holes the same? Is the way of attaching the brakeline the same? Quote Link to comment Share on other sites More sharing options...
zuendapp Posted April 27, 2016 Report Share Posted April 27, 2016 I am newer to trials and GasGas and do not have experience with older models with Formula brake components. My friends have had trouble with Brakum Teck with metal in the rear master cylinder and cut seals. I have changed to the Jitsie ( Beta style ) rear master cylinder kit for my 2014 GasGas. The Jitsie kit isn't a bolt on deal, you must modify / adjust for alignment. Also I had to take a ball-peen hammer to make clearance for the exhaust. So far I am happy with the performance and hopefully better reliability. This maybe a option for you? Quote Link to comment Share on other sites More sharing options...
anotherfive Posted April 28, 2016 Author Report Share Posted April 28, 2016 Thanks. i stripped it and took it to the shop. The braketec parts fit perfectly but if you're changing I'd check old against new. Think it was 9.5mm kit. All good now for £20. Quote Link to comment Share on other sites More sharing options...
