jml Posted April 27, 2016 Report Share Posted April 27, 2016 (edited) Hey all, I was adjusting my F/Brake lever position outboard today and I noticed that if I try to move the master cylinder/lever too close to the throttle it ends up fouling. Is this normal? Never noticed this on my Beta. Throttle is the standard domino, Master cylinder is also the standard one fit to the bike (braktec). Edited April 27, 2016 by jml Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 27, 2016 Report Share Posted April 27, 2016 (edited) You can reposition everything, so it might just need some adjustment. You can turn the throttle a bit, move the master cilinder a bit more inward, etc. A picture might make your problem more clear. Edited April 27, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
jml Posted April 27, 2016 Author Report Share Posted April 27, 2016 Photo is not of my bike, but identical set up. If I move the master close to the throttle tube, so outboard of the bike. A (the base of the brake lever) eventually will start to hit B (the back of the throttle tube). This never happened on my Beta no matter how close I put the two. Quote Link to comment Share on other sites More sharing options...
cascao Posted April 27, 2016 Report Share Posted April 27, 2016 Rotating your handlebar forward can help in case of your lever is close to the bend.... Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted April 27, 2016 Report Share Posted April 27, 2016 (edited) Something is ''off''. What happens if you try to move the master more inwards? In my opinion you would want to have it quite far inwards. Its better for your levers in case of a drop, and you can hold the outside of the handlebars, and hold the lever with two or one finger. Edited April 27, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
lineaway Posted April 28, 2016 Report Share Posted April 28, 2016 (edited) Usually you move the lever just opposite to have more leverage. But it has nothing to do with brand, it`s the `new` mc from BT. Edited April 28, 2016 by lineaway Quote Link to comment Share on other sites More sharing options...
jml Posted April 28, 2016 Author Report Share Posted April 28, 2016 Where I have it now feels okay, but it doesn't give you as much freedom as the Grimeca Mcyl Quote Link to comment Share on other sites More sharing options...
