Flywheel Weight Removal
glynn
Heres probably a stupid question, but before I strip the casing off my 03 TXT Pro is the fitted flywheel weight removable, or will I need to buy a standard flywheel and swap it out?
Cheers
Its a 2003 pro, it was originally a 125cc but bored to 200 so im guessing it will be the 125 flywheel with additional weight. I will get the side casing off this weekend and have a look what one it has, cheers :)
It has the 175cc piston from the TXT Pro 200, original 125cc stamped barrel was bored. Its definitely not a 125 as I have a spare 07 barrel and piston and it is alot smaller.
Edited by glynn
