glynn Posted May 3, 2016 Report Share Posted May 3, 2016 Heres probably a stupid question, but before I strip the casing off my 03 TXT Pro is the fitted flywheel weight removable, or will I need to buy a standard flywheel and swap it out? Cheers Quote Link to comment Share on other sites More sharing options...
fastbelly Posted May 3, 2016 Report Share Posted May 3, 2016 should unbolt it. Quote Link to comment Share on other sites More sharing options...
glynn Posted May 3, 2016 Author Report Share Posted May 3, 2016 So the aftermarket weight bolts on to the original flywheel? so it isnt a complete replacement? Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 3, 2016 Report Share Posted May 3, 2016 Yes its additional Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 4, 2016 Report Share Posted May 4, 2016 Did not realise it could be a 200. Also depens on the year. But on all 250's + flywheel weights are additional, just with some bolds. Quote Link to comment Share on other sites More sharing options...
glynn Posted May 4, 2016 Author Report Share Posted May 4, 2016 Its a 2003 pro, it was originally a 125cc but bored to 200 so im guessing it will be the 125 flywheel with additional weight. I will get the side casing off this weekend and have a look what one it has, cheers Quote Link to comment Share on other sites More sharing options...
nigel dabster Posted May 4, 2016 Report Share Posted May 4, 2016 bored to 200? are you sure? Quote Link to comment Share on other sites More sharing options...
glynn Posted May 4, 2016 Author Report Share Posted May 4, 2016 (edited) It has the 175cc piston from the TXT Pro 200, original 125cc stamped barrel was bored. Its definitely not a 125 as I have a spare 07 barrel and piston and it is alot smaller. Edited May 4, 2016 by glynn Quote Link to comment Share on other sites More sharing options...
