imexian Posted May 4, 2016 Report Share Posted May 4, 2016 Hi, I did have a list of all the sizes and serial numbers for the rear suspension bushes, also tensioner bush, now i cannot dig it out! Can anyone help with this please? Regards, Ian Quote Link to comment Share on other sites More sharing options...
ric h Posted May 4, 2016 Report Share Posted May 4, 2016 Post #13. http://www.trialscentral.com/forums/topic/50074-ossa-tr280i-swingarm-bearings-and-bushes/?hl=%2Bswingarm+%2Bbushings#entry361103 Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 5, 2016 Report Share Posted May 5, 2016 I have info also. Note the later 2015 bikes have a 20mm centre rocker shaft. I bought a box of the other bushings. Mark Quote Link to comment Share on other sites More sharing options...
tcrhino Posted May 5, 2016 Report Share Posted May 5, 2016 Sizes for 2015 model: Dogbones in swingarm: SKF 16 120 P10 Rocker - central pin: SKF PAF20 165 P10 Rocker - frame pin: SKF 16 17 0 P14 Quote Link to comment Share on other sites More sharing options...
imexian Posted May 6, 2016 Author Report Share Posted May 6, 2016 Thanks v much for info dudes? Quote Link to comment Share on other sites More sharing options...
imexian Posted May 6, 2016 Author Report Share Posted May 6, 2016 Which size is swing arm please ? Quote Link to comment Share on other sites More sharing options...
imexian Posted May 6, 2016 Author Report Share Posted May 6, 2016 Sorry I mean chain tensioner!! ? Quote Link to comment Share on other sites More sharing options...
tcrhino Posted May 6, 2016 Report Share Posted May 6, 2016 Sorry I mean chain tensioner!! ? Same size as the pin that links the frame to the rocker: SKF 16 17 0 P14 Quote Link to comment Share on other sites More sharing options...
imexian Posted May 12, 2016 Author Report Share Posted May 12, 2016 Also what's best way of getting bushes out? I only have normal tools etc, no machinery as such. Quote Link to comment Share on other sites More sharing options...
tsiklonaut Posted May 12, 2016 Report Share Posted May 12, 2016 Ian, I suppose you could try "village mechanic" style by kicking them out with a correct sized socket, but since the bushes are very shallow you can damage the bore in the process. I recommend getting a proper internal bearing puller kit. Quote Link to comment Share on other sites More sharing options...
imexian Posted May 12, 2016 Author Report Share Posted May 12, 2016 Hi margus, you think like the ones on eBay ? About £15.00? Is there a type I need to look out for? Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 12, 2016 Report Share Posted May 12, 2016 (edited) I've taken them out various methods. If desperate, you can crush one- get it out, then drive the other out with appropriate pipe/socket etc. Warming up the swingarm helps, so does some penates riding fluid. I've been using a bearing removeal tool for quite awhile. It wasn't that much and makes it super easy. (Slide hammer, expanding 'shoe') I'll have to see what brand, Mark Like this (I think that price is just a collet-) http://www.amazon.com/Motion-Pro-Bearing-Removal-08-0501/dp/B007GR4POW/ref=sr_1_4?ie=UTF8&qid=1463089422&sr=8-4&keywords=blind+hole+bearing+puller+set Edited May 12, 2016 by lotus54 Quote Link to comment Share on other sites More sharing options...
tsiklonaut Posted May 13, 2016 Report Share Posted May 13, 2016 Like this (I think that price is just a collet-) http://www.amazon.com/Motion-Pro-Bearing-Removal-08-0501/dp/B007GR4POW/ref=sr_1_4?ie=UTF8&qid=1463089422&sr=8-4&keywords=blind+hole+bearing+puller+set Yep, this one looks decent enough. You can use the same puller kit for the most internal stuff, wheel bearings, bushes etc etc. Quote Link to comment Share on other sites More sharing options...
imexian Posted May 19, 2016 Author Report Share Posted May 19, 2016 I've got chain tensioner bush out, by bashing the outside lip to bits then crushing it in!! Looks a major job for all the others!!! ? Can someone show me the item to get to make job quick and easy???? I've got some bushes but I need to get some more....anyone have a definitive list of all of them with serial numbers for each one and type please? Thanks Ian Quote Link to comment Share on other sites More sharing options...
lotus54 Posted May 20, 2016 Report Share Posted May 20, 2016 Didn't someone post the numbers? I have them all- I'll try to get them tomorrow. I may have some pics of replacing them also. I was going to do a video- but was out of time to get something setup. The bearing puller I put the link to makes it really easy Quote Link to comment Share on other sites More sharing options...
