Ecu Error
lotus54
If its standard OBDII which there is no good reason why it should not be then:
P tells you it is an engine or transmission fault
1 (the first 1) tells you it is a manufacturer specific code
6 tells you its computer output circuit
11 tells you it the camshaft position sensor but since your Ossa does not have a camshaft and the first 1 tells you it is a manufacturer specific code you will need a list of Kokusan Denki codes (for early ossas) or maybe Mahle codes for later ossas?
At a guess drive circuit will refer to the fuel pump or fuel injector, there is not as far as I know any other driven circuits on an Ossa.
