Stem Top Bolt Torque?
heffergm
No but if you look at the manual the swingarm pivot is 60 _70 nm and the stem is a similar size and function
It will be one of the higher tourqe bolts on the bike so just use your judgement
More important is the lock ring on the steering bearing , not a lot can happen even if the stem bolt comes loose ( provided you've clamped the fork legs back up
Tighten it and just keep your eye on it
