Pre 65 Tank Front Retaining Strap
andy m
Does anyone know where I can get the front fuel tank retaining rubber strap, the type used on the Holtworks style tank that hold around the mushroom / bobbin type thing at the front. Thanks in advance
Hi there,
I once had a bike with an alloy tank secured with a circular section rubber band. When it failed I used the drive belt from a Hoover upright vacuum cleaner. They might not be available anymore but could be worth looking for.
I think the belt Andy means has a loop at each end, single strand in between and is black in colour, maybe 10mm diameter x 150mm long. Similar straps are sometimes fitted to cars to hold the jack in place, try Autohose Milton Stoke on Trent 01782-542486
Edited by trialsrfun
