Montesa Cota 123
baurespdx
clutch drag
possible causes:
incorrect adjustment (too much freeplay)
insufficient travel (wrong handlebar lever ratio or lengthened arm on camshaft)
plates not flat
spring pressure not set evenly
sticky surfaces on plates
grooves worn into basket fingers
It is fairly normal to have more clutch drag when the motor is stopped due to the difference between static friction and dynamic friction between the plates
