toshy Posted May 27, 2016 Report Share Posted May 27, 2016 Hi I have a 2008.5 txt raga 300 and am trying to service my fork. I dropped the lowers and drained the oil, I tried to remove the top caps but they are attached to the spring assembly. I am not sure what type of forks they are. It says Sachs on the fork stickers so I would assume that's what they are?? I am not to sure how to set the oil height as the spring assembly is attached to the top cap??? Any suggestions Quote Link to comment Share on other sites More sharing options...
lineaway Posted May 27, 2016 Report Share Posted May 27, 2016 Pull the spring down off the top cap and you should see the nut you need to loosen. Quote Link to comment Share on other sites More sharing options...
wakka Posted May 27, 2016 Report Share Posted May 27, 2016 Good luck ,let me know how you get on Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted May 27, 2016 Report Share Posted May 27, 2016 It should be marchossi's but there were some troubles arround them, mine came with paolli's. If you pull the spring down, you can get a wrench on the bold, which will also lock the spring preventing it going back up again. Then you can undo the cap. Quote Link to comment Share on other sites More sharing options...
toshy Posted May 27, 2016 Author Report Share Posted May 27, 2016 (edited) Marzocchi forks they are, I got them striped and back together. The rebound leg rod appears to be off centre in the stanction, could my cartridge be bent?? The compression side feels ok but still has some stiction feels like it's coming from within the dampener cartridge not to sure what to do about this Edited May 27, 2016 by toshy Quote Link to comment Share on other sites More sharing options...
