hughesy Posted May 29, 2016 Report Share Posted May 29, 2016 Hi, looking for some advice, I'm currently rebuilding a 330 Montesa and can't find enough detail in the manual to solve the following: • what is the arrangement with the lower rear shock mount? I've replaced the spherical bearing. Is there a bush that fits inside this or a shouldered bolt? • does anyone have simplified wiring diagram? Does the pink wire from the stator go to a kill switch then to earth? • is it worth moving condenser up to underneath tank? What's the best way to do this? Any help appreciated. Steve Quote Link to comment Share on other sites More sharing options...
essexukay Posted April 10, 2020 Report Share Posted April 10, 2020 Hi steve, I have come across this myself. I believe there is a small top hat that goes either side of the bearing that sits inside the rear shock bottom mount. With regards the loom i did away with the loom and run just the red to the coil as I have no lighting kit. I believe the pink is for the rear brake pedal switch. Quote Link to comment Share on other sites More sharing options...
