baurespdx Posted May 30, 2016 Report Share Posted May 30, 2016 Hello everyone! we gave the carb a real good cleaning and she starts ok. But, she idles a little rough and as soon as we give her gas the engine makes a deep bogging sound then the RPMs pick up with throttle. We adjusted the pilot and idle screw and played with the settings to no avail. We also cleaned the exhaust. Any advice? Thanks, Adrien Quote Link to comment Share on other sites More sharing options...
feetupfun Posted May 30, 2016 Report Share Posted May 30, 2016 partially or fully blocked pilot jet or pilot mixture passage Quote Link to comment Share on other sites More sharing options...
cleanorbust Posted May 30, 2016 Report Share Posted May 30, 2016 (edited) You'd have to remove the pilot jet to clean it thoroughly, not sure if you did this when cleaning the carb. Make sure you use a well-fitting screwdriver, the jets can easily get chewed up if the fit isn't good. Edited May 30, 2016 by cleanorbust Quote Link to comment Share on other sites More sharing options...
kingscorpion Posted May 31, 2016 Report Share Posted May 31, 2016 A 4x1 mm flat screwdriver will fit perfectly. Quote Link to comment Share on other sites More sharing options...
