spenser Posted July 20, 2021 Report Share Posted July 20, 2021 On 6/17/2021 at 1:30 PM, Trials124 said: Did you turn the idle up on the stop adjuster behind the exhaust ? I had no issue with a low idle, but have been having high idle issues. I think it happens when I ride in wet conditions as the bike started to run very well when the rains stopped and it had a chance to dry out. Higher idle returned a couple of hours after riding again during rain showers, so thinking I need to go through the electrics. Another friend with a 2018 250 found a burnt/melted plug under the flywheel cover which was causing him various issues. Spencer Quote Link to comment Share on other sites More sharing options...
magnapoxy Posted July 20, 2021 Report Share Posted July 20, 2021 When Similar & Dissimilar metals contact each other it causes these areas to deteriorate. Example- where the connector wires enter the pins on the connectors. And- if the connector pins are not the same metal as the pin sockets . same thing. This uses lightly - 1st Flush unplugged connectors with CRC Electronic cleaner. Then Buy a small spray can of this--- Caig Labs G- series Deoxit Gold G-5. Use it lightly on connector pins & sockets. There are other final treatments that could be used also-- Example- nano particle silver in a low die electric grease.---- Apply with a q-tip - lightly. A good electronic & high end audio store will know about these items-- I use these items all the time- rebuilding & building home audio equipment. Do NOT use carb or brake cleaner on connectors- it will destroy plastics. Quote Link to comment Share on other sites More sharing options...
Dede80 Posted July 21, 2021 Report Share Posted July 21, 2021 Il 13/7/2021 alle 00:16, KmK ha scritto: C'è un problema con i tappi incrostati. Alcuni ciclisti con vertigini non hanno questo problema. Ma la mia bici sporca la spina ogni poche ore. La moto va bene e poi non parte. Spina nuova e si accende al primo colpo. Non credo che cambiare la candela ogni due ore sia una buona soluzione. did you find the solution to your problem? Quote Link to comment Share on other sites More sharing options...
