mcman56 Posted May 30, 2016 Report Share Posted May 30, 2016 I have a 2014 Factory model and noticed that the grommet that is the top mount is broken and there is some play. Is there a way to sneak in a new one or do you really have to pull the entire radiator, hoses, fan, etc. Quote Link to comment Share on other sites More sharing options...
iridebikes Posted May 31, 2016 Report Share Posted May 31, 2016 Have to drop the radiator down but can leave hoses and everything attached, and from there you can just put it in and reattach the mounts. If I'm honest the rubber grommets are terrible as I ripped two out in 2 months so we put another In and then cable tied the radiator back so it doesn't have as much movement and not had a problem since Quote Link to comment Share on other sites More sharing options...
