thegscott Posted June 1, 2016 Report Share Posted June 1, 2016 Beta evo 300 2015 noisy out of gear clutch out noisy clutch in less noisy is there a problem the clutch noisy from standard thanks form your help ps how do I send a video I Quote Link to comment Share on other sites More sharing options...
steve_earle Posted June 1, 2016 Report Share Posted June 1, 2016 That's gears rattling, I won't go into the science behind it but normal on most trials bikes, My Beta does it, The Gas Gas makes a hell of a racket. Quote Link to comment Share on other sites More sharing options...
evoalien Posted June 2, 2016 Report Share Posted June 2, 2016 Does it quiet down when you pull the clutch lever In ???? Quote Link to comment Share on other sites More sharing options...
thegscott Posted June 2, 2016 Author Report Share Posted June 2, 2016 Yes when I pull the clutch in Quote Link to comment Share on other sites More sharing options...
fastbelly Posted June 2, 2016 Report Share Posted June 2, 2016 Normal. Quote Link to comment Share on other sites More sharing options...
thegscott Posted June 2, 2016 Author Report Share Posted June 2, 2016 I have a 2012 and it don't make a noise Quote Link to comment Share on other sites More sharing options...
heffergm Posted June 2, 2016 Report Share Posted June 2, 2016 Bueller? Bueller? Quote Link to comment Share on other sites More sharing options...
feeley1 Posted June 3, 2016 Report Share Posted June 3, 2016 I have a 2014 factory and mine does it. Clutch in fine but riding it is noisy. Same as you. Is it normal? Not had it long. Seems to run and ride well. It's like a wuring noise if you know what I mean. Quote Link to comment Share on other sites More sharing options...
thegscott Posted June 3, 2016 Author Report Share Posted June 3, 2016 Does it change tone when you pull the clutch in? Quote Link to comment Share on other sites More sharing options...
feeley1 Posted June 3, 2016 Report Share Posted June 3, 2016 when clutch is in, it sounds as it should Quote Link to comment Share on other sites More sharing options...
feeley1 Posted June 3, 2016 Report Share Posted June 3, 2016 the noise is when your going. more noticeable as you move up the gears. Quote Link to comment Share on other sites More sharing options...
thegscott Posted June 4, 2016 Author Report Share Posted June 4, 2016 Not a problem then Quote Link to comment Share on other sites More sharing options...
