paulmac Posted June 3, 2016 Report Share Posted June 3, 2016 I'm having problems with clutch stick on my 2015 300 and started by bleeding the clutch circuit (Braketec). A mate gave me top tip which you all may know, but since I didn't see it on this forum I thought I'd share it. Bleeding from the top down is a pain in the provable and takes for ever but if you remove the top cover then undo the master cylinder from the crankcase (thoroughly cleaning the area first) you can bleed form the bottom up by pulling in the clutch leaver and carefully pushing in the piston on the master cylinder - magic happens and the air shoots out of the top reservoir (bit messy so have a rag handy) . Hope this helps some other folk. Paul Mac 1 Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 3, 2016 Report Share Posted June 3, 2016 The master cylinder is on the bars, I assume you are talking about the slave cylinder. Be very carful not to pop the slave`s piston out. Quote Link to comment Share on other sites More sharing options...
paulmac Posted June 3, 2016 Author Report Share Posted June 3, 2016 As lineaway says... good catch. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 3, 2016 Report Share Posted June 3, 2016 I just pump the lever with the master cylinder at the highest point. I do the same with the front brake. But the back brake that's a pain Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted June 3, 2016 Report Share Posted June 3, 2016 (edited) Back brake tip: get some pressure with the normal methods (or by reverse flushing the circuit, or with vacuum pump). Ride, with the brake on if it does not slip you have air, make sure its hot and put some water on the brake. Or remove the wheel and let the brake hang down (put it on the disk though) than bleed it. The problem is in the angle. Edited June 3, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
crusoe123 Posted June 4, 2016 Report Share Posted June 4, 2016 Forget all of those approaches, get yourself a vaccum pump. EBay for about 20 quid, and put it on the bleed nipples and pump away, whilst topping the reservoirs. Quote Link to comment Share on other sites More sharing options...
cascao Posted June 6, 2016 Report Share Posted June 6, 2016 Clutch sticking when? If it happen when bike was stopped for a long time, it's not hydraulic related Quote Link to comment Share on other sites More sharing options...
paulmac Posted June 6, 2016 Author Report Share Posted June 6, 2016 Hi cascao - it wasn't hydraulic - just my staring point. Plates were stuck together - new plates going in today. Cheers Quote Link to comment Share on other sites More sharing options...
