Rev 3 Help Please!
sy250
Just bought a Rev 3 250 (2002).
Drained gearbox and 300 ml came out. Is this normal ? Thought they held 550 ml. ??
What gearbox oil would you recommend to use ?
Is the petrol tap "off" when arrow is pointing towards the back of the bike ??
Thanks for reading this and thanks in advance for any advice .
The rev 3 takes 550ml,but this is when gearbox is fully drained ie. after a rebuild.I put about 520 ml in mine at oil changes and always use PJ1 CLUTCH LIGHTENER 75 wt.By the way if the engine was cold it still would not keep 200ml in gearbox.take out drain bolt and leave overnight,and remember to also take out filling cap bolt while draining.put new oil in next day and run bike checking all casing bolts are tight.sometimes these work loose the bottom one on the left near the bashplate is sommetimes the one that works loose i think you can't see it on the early models and have to loosen bashplate to move the rubber to gain access.
Edited by PRW
  • 17 years later...
