barryb1973 Posted June 24, 2016 Report Share Posted June 24, 2016 thanks,i ordered bearings today and seal not much choice in uk who you get them off and the type they are,i run atf in mine it looks like strawberry milkshake at minute so i may have some water ingress aswell Quote Link to comment Share on other sites More sharing options...
barryb1973 Posted June 25, 2016 Report Share Posted June 25, 2016 Bearings arrived jitsie packaged xgf type am i right in thinking i only need one other seal for flywheel side with these type of bearings Quote Link to comment Share on other sites More sharing options...
twowheelfanatic Posted June 25, 2016 Author Report Share Posted June 25, 2016 engine noise growling type noise.if you use screwdriver you can here it through the cases Quote Link to comment Share on other sites More sharing options...
barryb1973 Posted June 25, 2016 Report Share Posted June 25, 2016 Started to tear down today ,theres no obvious play in shaft at either end i know sometimes its not possible to feel it just by man handling it,also the clutch basket bolts are star type shape is there a special socket to get them off Quote Link to comment Share on other sites More sharing options...
huski Posted June 25, 2016 Report Share Posted June 25, 2016 7mm ring spanner fits the clutch bolts,not that you need to touch them.You can remove the clutch complete by removing the 4mm Allen head bolt which holds it onto the shaft Quote Link to comment Share on other sites More sharing options...
barryb1973 Posted June 25, 2016 Report Share Posted June 25, 2016 So it does thanks,clutch basket has lot of movement on it so have to change that bearing aswell,water pump shaft has play aswell, looking at oil its got water in so need to rebuild pump Quote Link to comment Share on other sites More sharing options...
barryb1973 Posted June 25, 2016 Report Share Posted June 25, 2016 So it does thanks,clutch basket has lot of movement on it so have to change that bearing aswell,water pump shaft has play aswell, looking at oil its got water in so need to rebuild pump do all the clutch baskets have play on shaft or is my bearing shot Quote Link to comment Share on other sites More sharing options...
toolguy Posted September 22, 2016 Report Share Posted September 22, 2016 Jim, are there VIN numbers that these bearing issues are known to be found? I have the very last model of the TXTPRO 280 in the warehouse. I bought mine in October 2014. I've got less than 30 minutes on it since servicing it. Thanks, Gordon Quote Link to comment Share on other sites More sharing options...
breagh Posted September 22, 2016 Report Share Posted September 22, 2016 Sorry to drift a bit, if I understand correctly the bearings are lubed by the transmission oil and not the pre mix? I've an Ossa that has had issues and i'm praying that poor bearing quality has been the cause and is now fine. Anyone put my mind at rest before next years Scottish. Quote Link to comment Share on other sites More sharing options...
breagh Posted September 22, 2016 Report Share Posted September 22, 2016 Thanks Jim, so me running the bike a bit richer to save them was in vain. What a pudding I am. I can't mind what transmission oil I've been using it's some fancy synthetic ATF, it always comes out like new when changed. Should I be using something different? Cheers. Quote Link to comment Share on other sites More sharing options...
baldilocks Posted September 22, 2016 Report Share Posted September 22, 2016 No I've been running either atf or putoline light gear oil for years. My current bike was new in march 14, I've just changed the mains recently but only because I was splitting the cases to change the needle rollers as a precaution. Mains were still perfect, annoyingly so we're the needle rollers but better safe than sorry 1 Quote Link to comment Share on other sites More sharing options...
toolguy Posted September 22, 2016 Report Share Posted September 22, 2016 Jim, I don't know when I'll get to start riding this bike, but I will and I want it right. I've waited 30 years to replace my old TY250 with this new 2014. Do you have a repair list of parts that I'll need to replace the bearings, seals, and gaskets? I want to replace them before I have hardened chrome metal chunks floating through my transmission oil. Thanks, Gordon Quote Link to comment Share on other sites More sharing options...
toolguy Posted September 23, 2016 Report Share Posted September 23, 2016 Thanks Jim. I'm in the states, so you'll be hearing from me. Quote Link to comment Share on other sites More sharing options...
aussiechris Posted September 27, 2016 Report Share Posted September 27, 2016 Hi Jim, You mentioned you only use XGF main bearings now. Are they the same a Xiu Engineering? The reason for asking is that 18 months ago I replaced the main bearings in my 2011 300 Raga (due to cracked crankcases) and I was talked into using the Xiu Engineering ones because they are lower friction and have long-life silicone seals. There was nothing wrong with the original bearings. Now I'm regretting that decision because my bike is consuming gearbox oil at an alarming rate and there are no external leaks. So it's looking like I will be tearing it down again and paying for yet another set of mains along with all the gaskets. If XGF is different from Xiu then maybe I'll go with them. Otherwise I need to source genuine Gas Gas bearings but don't know how to ensure I don't get the dud 2013-15 ones. Thanks, Chris. ps. I couldn't have done the last rebuild without your excellent videos. Thank you. Quote Link to comment Share on other sites More sharing options...
zippy Posted September 27, 2016 Report Share Posted September 27, 2016 Hi Jim, You mentioned you only use XGF main bearings now. Are they the same a Xiu Engineering? The reason for asking is that 18 months ago I replaced the main bearings in my 2011 300 Raga (due to cracked crankcases) and I was talked into using the Xiu Engineering ones because they are lower friction and have long-life silicone seals. There was nothing wrong with the original bearings. Now I'm regretting that decision because my bike is consuming gearbox oil at an alarming rate and there are no external leaks. So it's looking like I will be tearing it down again and paying for yet another set of mains along with all the gaskets. If XGF is different from Xiu then maybe I'll go with them. Otherwise I need to source genuine Gas Gas bearings but don't know how to ensure I don't get the dud 2013-15 ones. Thanks, Chris. ps. I couldn't have done the last rebuild without your excellent videos. Thank you. Could be the O-ring on the Crankshaft bushing is allowing the gearbox oil to leak past. Quote Link to comment Share on other sites More sharing options...
