peterb Posted July 14, 2016 Report Share Posted July 14, 2016 If it is the ECU at fault, you can replace it with another ECU with either the earlier or later firmware. The earlier firmware does not support the easy start system, which is no big drama. The later firmware can be "flashed" into your existing ECU or into an earlier firmware ECU by a company in Spain. I have had this done, installing the later firmware on a 2012 ECU but must say that it took about as long as building Hadrians wall. Minimal cost. PM me if you would like more info. Also, not sure if I posted this before, but we did have a problem with an intermittent break in one of the wires going into the ECU, right on the tight angle where the connector clips into place. Bye, Peter B. Quote Link to comment Share on other sites More sharing options...
dadof2 Posted July 15, 2016 Report Share Posted July 15, 2016 Have you tried new fresh petrol, fuel filter condition and fuel pump pressure? Take the bike to a local automotive diagnostic technician and ask him to check the HT voltage waveform. Should take less than 5 minutes. Most if not all of the Ossas EFI and ignition components can be easily disconnected and individually tested. If bike was mine I would check all the components one at a time and continuity / resistance (under load) in the wiring harness. ECUs are solid state and generally very reliable Check the stability and values of the regulated voltage. Have you tried to check for a spark at the plug or kicked the bike over with the plug lead disconnected or the plug not earthed? If so this could trash the ecu. Try phoning round ECU testers / repairers in hope that one can test your ECU. Quote Link to comment Share on other sites More sharing options...
chudder Posted September 14, 2016 Report Share Posted September 14, 2016 badger, did trials + trib sort your bike or is it in a skip.Mine has lost power,starts 1st time and revs ok but under load starts dieing.Pull clutch in and it revs up again. Quote Link to comment Share on other sites More sharing options...
badger360 Posted September 14, 2016 Author Report Share Posted September 14, 2016 Yes trials and tribs are very good they know there stuff ,sound like the tps needs re setting or clean the tps connection to the throttle body or could be a loose connection to the fuel injector check all your plugs what year is the bike Quote Link to comment Share on other sites More sharing options...
chudder Posted September 14, 2016 Report Share Posted September 14, 2016 That's good news,mines a 2011.Had it 18months.been great till now.Thanks for the suggestions.I am only 30miles or so from trials and tribs if I cant cure it. 1 Quote Link to comment Share on other sites More sharing options...
badger360 Posted September 24, 2016 Author Report Share Posted September 24, 2016 Have you fixed the bike yet Quote Link to comment Share on other sites More sharing options...
chudder Posted September 27, 2016 Report Share Posted September 27, 2016 Just took it to trials and trib,hope they can sort it.What was wrong on yours in the end badger? Quote Link to comment Share on other sites More sharing options...
badger360 Posted September 27, 2016 Author Report Share Posted September 27, 2016 Needed a new throttle body and tps re setting ,Trials and Tribs will fix it Ian knows his stuff Quote Link to comment Share on other sites More sharing options...
chudder Posted October 3, 2016 Report Share Posted October 3, 2016 New throttle body,up and running again. Quote Link to comment Share on other sites More sharing options...
