sectionone Posted December 1, 2016 Report Share Posted December 1, 2016 How much pressure do you use? My HVAC guy said I can use his nitrogen tank. Maybe I can install a shrader valve? I have some worn out twin shocks from an 80's bike that had little/no damping left. I drilled a hole, drained the oil, welded a nut on, added power steering fluid, and closed up with a bolt. The damping is pretty good now. I want to try the same procedure with an old Fantic Section shock, add a shrader valve and pressurize with nitrogen, then if that works, try it on the Sachs. Quote Link to comment Share on other sites More sharing options...
lineaway Posted December 2, 2016 Report Share Posted December 2, 2016 150 would work. You really should try to take it apart and replace the seals. It is real cheap if you go to a hydraulic shop and have them measured up. Less than 20 bucks for seals and o rings on my Ohlins. 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted December 2, 2016 Report Share Posted December 2, 2016 Agree. Remembering that this "new modern" shocks have a piston separating oil and gas. So, one hole for oil and gas does not work any more. If a shrader valve is too big for your shock, you can use a KTM M5 style bolt (neoprene seal and needle system) witch require a special inflating device. 1 Quote Link to comment Share on other sites More sharing options...
sectionone Posted December 2, 2016 Report Share Posted December 2, 2016 Here's the link: http://advrider.com/index.php?threads/rebuild-the-unrebuildable-sachs-zf-shock-gasgas-other.1170705/ Good stuff. I'm going to give it a try. The author also has a detailed instructions on aluminum marzochhi forks. http://advrider.com/index.php?threads/marzocchi-fork-maintenance-de-mystefied.1018648/#post-28415949 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted January 10, 2018 Report Share Posted January 10, 2018 Few photos of some friends shocks I resurrected. https://www.flickr.com/photos/cascao/albums/72157677115009136 Quote Link to comment Share on other sites More sharing options...
baldilocks Posted January 12, 2018 Report Share Posted January 12, 2018 Can I ask how they pressurise a new shock without an external valve if you have to have one to rebuild it ? Quote Link to comment Share on other sites More sharing options...
Wideopen Posted May 1, 2019 Report Share Posted May 1, 2019 Ciao cascao, thank's for sharing your knowledge with your nice video. I' m gonna service the Sachs shock of my gg txt 280 2000 and I would like to know how many cm the air/gas piston separator should enter in the schock absorber body. i can't see the measurement you made on your video. Cheers from Italy . Thanks 1 Quote Link to comment Share on other sites More sharing options...
cascao Posted May 1, 2019 Report Share Posted May 1, 2019 On 5/1/2019 at 6:14 AM, Wideopen said: Ciao cascao, thank's for sharing your knowledge with your nice video. I' m gonna service the Sachs shock of my gg txt 280 2000 and I would like to know how many cm the air/gas piston separator should enter in the schock absorber body. i can't see the measurement you made on your video. Cheers from Italy . Thanks Expand do not know how many they use from factory. On shocks I reassembled used the rule below: Meassure shock shaft lenght that goes inside shock body (estimated pu bumper half compressed) and increase a little (10mm) Quote Link to comment Share on other sites More sharing options...
Wideopen Posted May 2, 2019 Report Share Posted May 2, 2019 On 5/1/2019 at 4:16 PM, cascao said: do not know how many they use from factory. On shocks I reassembled used the rule below: Meassure shock shaft lenght that goes inside shock body (estimated pu bumper half compressed) and increase a little (10mm) Expand ? perfect ? Quote Link to comment Share on other sites More sharing options...
Wideopen Posted May 7, 2019 Report Share Posted May 7, 2019 On 5/1/2019 at 4:16 PM, cascao said: do not know how many they use from factory. On shocks I reassembled used the rule below: Meassure shock shaft lenght that goes inside shock body (estimated pu bumper half compressed) and increase a little (10mm) Expand one more question... my shock it's not licking and works well. Only the bumper disapppear. Destroyed by the years Do you think it's possible to take apart the feet of the shock without depressurizing it, just to replace the bumper? obrigado Quote Link to comment Share on other sites More sharing options...
Wideopen Posted May 7, 2019 Report Share Posted May 7, 2019 On 5/7/2019 at 4:36 PM, Wideopen said: one more question... my shock it's not licking and works well. Only the bumper disapppear. Destroyed by the years Do you think it's possible to take apart the feet of the shock without depressurizing it, just to replace the bumper? obrigado Expand forgot to tell you .... sachs schock from a gas gas txt 280 2001 Quote Link to comment Share on other sites More sharing options...
cascao Posted May 7, 2019 Report Share Posted May 7, 2019 On 5/7/2019 at 4:36 PM, Wideopen said: one more question... my shock it's not licking and works well. Only the bumper disapppear. Destroyed by the years Do you think it's possible to take apart the feet of the shock without depressurizing it, just to replace the bumper? obrigado Expand Yes. You just need do unscrew shock bottom clevis (use heat to broke loctite and aluminium clamps to protect the shock stem) It good practice change rebound bolt o rings due heat you used Cut car bumper or buy new one from splat shop (gasgas bumper is sheaper than shercos) Quote Link to comment Share on other sites More sharing options...
Wideopen Posted May 8, 2019 Report Share Posted May 8, 2019 On 5/7/2019 at 9:29 PM, cascao said: Yes. You just need do unscrew shock bottom clevis (use heat to broke loctite and aluminium clamps to protect the shock stem) It good practice change rebound bolt o rings due heat you used Cut car bumper or buy new one from splat shop (gasgas bumper is sheaper than shercos) Expand ? Done..... thank's a lot ? Quote Link to comment Share on other sites More sharing options...
