nzpeterb Posted June 11, 2016 Report Share Posted June 11, 2016 I have a 2014 TXT 250 and want to remove the clutch hub and basket to get to the kickstart bearing. I have the clutch centre bolt and washer out but even with a heat gun I cannot get the clutch off the shaft. The parts book doesn't seem to show anything extra, and I know from experience the earlier basket just pulls off. To I need to resort to more heat (a flame) or have I missed something? Anyone have any ideas? Regards Peter. Quote Link to comment Share on other sites More sharing options...
lineaway Posted June 11, 2016 Report Share Posted June 11, 2016 (edited) Seems like I saw someone with a later model pro having the same issue.. The early years needed prying out from both sides at once. Edited June 11, 2016 by lineaway Quote Link to comment Share on other sites More sharing options...
nzpeterb Posted June 11, 2016 Author Report Share Posted June 11, 2016 Thanks for the reply. Heating it a couple of times got the basket moving slightly. Then pushing the basket in and out slowly gained more play until the inner hub popped free. It seemed a lot tighter than the 07 we also have. Anyway, thanks again. Next is knocking the kickstart bearing out. i am trying to reduce the wiggle in the kickstart shaft which is way worse on the 14 than the 07. Regards Peter. Quote Link to comment Share on other sites More sharing options...
arnoux Posted June 11, 2016 Report Share Posted June 11, 2016 (edited) There is a tool for removing the clutch. GG part number T0118090 Or you can just go to the Bolt shop and get (from memory) a M18 bolt about 90mm long. If you look inside the clutch centre you will see the internal thread. Wind the bolt into this and it pops the whole shooting match off. Edited June 11, 2016 by arnoux 1 Quote Link to comment Share on other sites More sharing options...
baldilocks Posted June 11, 2016 Report Share Posted June 11, 2016 Arnoux thankyou Quote Link to comment Share on other sites More sharing options...
nzpeterb Posted June 11, 2016 Author Report Share Posted June 11, 2016 Thanks Arnoux. I could not work this out until I got it apart as there is only two turns of thread and it was difficult to see. The thread on mine is M18 x 1.50 pitch so Metric fine. Hope this information helps someone else. regards, Peter. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted June 13, 2016 Report Share Posted June 13, 2016 Never knew this (did not need it) but good tip! Saw jim schnell made the same remark in another thread. Also the front gear on the crankshaft is stuck somethimes. There is suposed to be a tool for this aswel. On one of my bikes its stuck, havent got it loose yet. Quote Link to comment Share on other sites More sharing options...
Pastmyprime Posted August 14 Report Share Posted August 14 I removed my GG clutch recently and discovered what you guys discussed back in 2016, so I'd like to get the bolt. Are you pretty sure about the M18x1.5 threads? I tried to look at and/or measure the threads on the bottom of my clutch hub, but it was difficult to see. Based on what I could see & measure, I thought it was M18x1.25, but I could easily be mistaken. Let me (us) know thanks Quote Link to comment Share on other sites More sharing options...
