4Rt Torque Spec
bulto58
Hi to all,
I'm going to be changing my oil's and fillter for the first time, and have all the info to carry out the work, except for the torque spec of the casing bolts.
would the bolts on the clutch side be the same Torque ( for future reference )
Thanks.
  On 6/12/2016 at 3:11 PM, bulto58 said:
Hi to all,
Thanks.
All bolts on 4RT not specifically covered in the manual use standard torque settings
5mm dia use 5NM 3.5lb/ft
6mm dia       10 NM, 7lb/ft
8mm dia       22NM 16lb/ft
Take care when replacing filter cover to push the cover fully home and square and hold it there as you fit the keeper and bolt and tighten. If you use the bolt to push the cover into the housing it will go off center and jam in the housing.
  • Like 3
