Caliper O Ring
diesel2607
Does anyone know if you can buy the small o rings from anywhere as brake is working just fluid seeping out of the split and I think air getting in there making brake soft
I learned this the hard way.  Just bear in mind that the top mounting bolt also seals the one half of the caliper.  If you pump the brakes with the bolt removed, it will leak.
