Map Switch Newbee
tman427
20016 Standard 4RT.
Can i switch between the two settings (1 dry and 2 mud) on the fly while the motor is running?
I have and nothing broke.
Can it be done while you are moving in gear?
Or are you suppose to shut down and then switch?
Also, i can not tell much difference between the two, the 2 map seems a bit softer and the 1st is a slight bit more aggressive.
Thanks
tom
