4stroke Posted June 20, 2016 Report Share Posted June 20, 2016 Can anyone confirm that the original engine in a Seeley is based on the XL185? If so do most parts fit, clutch, bearings, seals etc. Quote Link to comment Share on other sites More sharing options...
tlrmark Posted June 20, 2016 Report Share Posted June 20, 2016 Yes the Seeley Honda 200 used the 1979 XL185 engine. The carb and intake manifold and header pipe are TL125 1973-1976. Quote Link to comment Share on other sites More sharing options...
hondaphil Posted June 21, 2016 Report Share Posted June 21, 2016 Some parts will be the same but the crank, some of the gears , flywheel, cylinder- bored to 66mm, the outer cases are also slightly different as is the left crankcase and the gear change shaft. Quote Link to comment Share on other sites More sharing options...
