Montesa 242 Clutch Re-Build
exile
I am rebuilding a Montesa 242 and although the bike is low hours and relatively untouched, when I washed the clutch case and gearbox out with petrol, what looks like thrust washer dropped out of the primary case, evidence as you can see, a ham head took the clutch apart, the nut was also loose, has anyone any advice on dismantling these clutches please?
Many thanks
242.pdf
