caddy4u Posted June 30, 2016 Report Share Posted June 30, 2016 Just bought one guys! Few things, does anyone have or have a link to a workshop manual? Next, Clutch is awful, how to improve? Thirdly, got a tapping in the top end, what do I need to change the piston, was best to get it from and any hints and tips! Thank you very much! Quote Link to comment Share on other sites More sharing options...
jonnyc21 Posted July 1, 2016 Report Share Posted July 1, 2016 The 4RT and 315R clutch fix/oil threads should be easy to find. I seem to hear the most emphatic people update the clutch pack/plates. If your in the US I would contact Dennis at http://www.overlandtrail.biz, not sure about outside the US. If you want to try the oil fix's: 1) http://www.trialscentral.com/forums/topic/56402-elf-htx-clutch-and-gearbox-oil/ 2) http://www.trialscentral.com/forums/topic/60397-4rt-clutch-and-brake-mods/ 3) ... (Search for "clutch" in the Montesa forum) Quote Link to comment Share on other sites More sharing options...
slack Posted July 1, 2016 Report Share Posted July 1, 2016 Hi Caddy If you P/M i will pass on my number and will have a bit crack with you as i have recently bought the same bike. Quote Link to comment Share on other sites More sharing options...
caddy4u Posted July 2, 2016 Author Report Share Posted July 2, 2016 On 7/1/2016 at 4:24 AM, jonnyc21 said: The 4RT and 315R clutch fix/oil threads should be easy to find. I seem to hear the most emphatic people update the clutch pack/plates. If your in the US I would contact Dennis at http://www.overlandtrail.biz, not sure about outside the US. If you want to try the oil fix's: 1) http://www.trialscentral.com/forums/topic/56402-elf-htx-clutch-and-gearbox-oil/ 2) http://www.trialscentral.com/forums/topic/60397-4rt-clutch-and-brake-mods/ 3) ... (Search for "clutch" in the Montesa forum) Thank you buddy, most helpful! On 7/1/2016 at 10:33 AM, slack said: Hi Caddy If you P/M i will pass on my number and will have a bit crack with you as i have recently bought the same bike. PM sent buddy! Quote Link to comment Share on other sites More sharing options...
