hamill_glen Posted July 3, 2016 Report Share Posted July 3, 2016 Just wondering what other leavers are available for the 2013 model Quote Link to comment Share on other sites More sharing options...
lockie28 Posted July 3, 2016 Report Share Posted July 3, 2016 None unless you swap from the formula mastercylinders to AJP or grimeca .. If you do swap to ajp or grimeca front brake mastercylinder then you have to replace the caliper too! Quote Link to comment Share on other sites More sharing options...
tomevans Posted July 5, 2016 Report Share Posted July 5, 2016 S3 did levers but they were pretty average. You can replace the master cylinders on their own too, they use the same m10x1mm thread as the ajp, braktec or gremica master cylinders, although you may notice a change in feel with the brake as they use a slightly larger bore. Quote Link to comment Share on other sites More sharing options...
hamill_glen Posted July 5, 2016 Author Report Share Posted July 5, 2016 Think I'll just be changing the master cylinders ! As not to keen on the standered ones . Quote Link to comment Share on other sites More sharing options...
