vanman1950 Posted July 6, 2016 Report Share Posted July 6, 2016 Hi....looking at a 2014 st 300 as not getting on with my 320 4t. Any advice on known faults/problems with this model??? Thanks in advance....... Peter. Quote Link to comment Share on other sites More sharing options...
digger144 Posted July 7, 2016 Report Share Posted July 7, 2016 like comparing a rolls royce to a tractor Peter,st 300 is a good bike, good low down power, grips well, steers well,and starts very easily. Quote Link to comment Share on other sites More sharing options...
cord Posted July 25, 2016 Report Share Posted July 25, 2016 look for slop/play in the suspension. It is usually the ****e bushes/steel pins in the dog bones. Also air leaks from the rubber inlet between carb and reed block, the rubber splits if over tightened. (easy to fix with a smear of gasket sealant) Quote Link to comment Share on other sites More sharing options...
