Ty250 Mono Neutral Gear Issue
samwisemcg
Is this situation happening with the bike running ?   If it happens when the bike is not running then this is not normal. If it is happening when the bike is running, this is common for a lot of bikes regardless of brand. You will find it may be easier to find neutral if the clutch lever is pulled all the way to the handlebar when you try to select neutral.
It only ever happens with the engine off. Is this really normal? It makes moving the bike around a nightmare, plus also trying to start the bike when it won't stay in neutral is next to impossible.
Thanks for the help.
