Rev 3 Rear Master Cylinder (Would Pattern Aprilia One Fit?)
manxmann3
Hi
Got a 2005 Rev 3 250 needs new rear master cylinder
The aprilia rs125s of that era had grimeca master cylinders that look identical with 40mm bolt centres
Any reason why it shouldn't work if I fitted one
There are brand new pattern ones on eBay for 35quid including reservoir and hose compared to 90 for a grimeca
Thanks
Any master cylinder will work with any caliper, it's only a simple hydraulic system.
The thing to look for is the bore size of the master cylinder. Changing the bore size will change the power and feel of the system.
