ukmatador Posted July 16, 2016 Report Share Posted July 16, 2016 The bike, 1969 MK3 Matador with the above carb. Light throttle works fine with engine stationary. once started and for about 5 minutes the slide sticks part way open which is fun. Its a 32mm choke. Would the engine induction suction cause the slide to stick until the body expands slightly due to warming up? I'm wondering if a stronger spring, if available, would eliminate the problem. Quote Link to comment Share on other sites More sharing options...
collyolly Posted July 16, 2016 Report Share Posted July 16, 2016 Look at the condition of the slide, there is a small peg on the side that wears and can cause a jam. Old bike ,old carb they don't last long anyway ! Quote Link to comment Share on other sites More sharing options...
basil Posted July 16, 2016 Report Share Posted July 16, 2016 Don't discount the ethanol malarkey a build up soon jams the slide in my experience . 1 Quote Link to comment Share on other sites More sharing options...
sdm Posted July 17, 2016 Report Share Posted July 17, 2016 Is it a flange mount or spigot mount Amal? If it is flange mount the nuts might be torqued too tight warping the carb body causing the slide to stick. Sam 3 Quote Link to comment Share on other sites More sharing options...
ukmatador Posted July 17, 2016 Author Report Share Posted July 17, 2016 Good point basil, never thought of that and yes it is flange mounted. As I say the throttle works fine with the engine stationary but on start up for 5 mins. or so it sticks at mid point. I'm sure I have read somewhere that induction suction can cause problems with a tight slide. Am going to the VMCC day at Stanford Hall today so will see if a stronger spring is available, the throttle is very light. John Quote Link to comment Share on other sites More sharing options...
lineaway Posted July 17, 2016 Report Share Posted July 17, 2016 (edited) Assuming you have disassembled and soaked the whole body and parts in a carb cleaner overnight or more? Do you have all the parts for the slide, etc. The needle itself could be moving. Edited July 17, 2016 by lineaway 1 Quote Link to comment Share on other sites More sharing options...
ukmatador Posted July 18, 2016 Author Report Share Posted July 18, 2016 You were dead right basil. A thin film of varnish on slide and body. Carb cleaner cured it. I'm guessing its the residue from the tank which was dry. Bike was last used in 1974! Next problem is to cure the sticking clutch plates when stood for a couple of days. Brilliant forum by the way. John Quote Link to comment Share on other sites More sharing options...
lbhbul Posted July 18, 2016 Report Share Posted July 18, 2016 Try draining whatever is in the primary case, try to flush it a bit of diesel, ect, shift into 5th gear & pull the clutch in & rock it back & forth until the clutch plates come loose, drain the cleaner & re fill with 250 cc's of Dexron ATF , hopefully it will then work out for you. If the above does not help then its time for a tear down on the clutch side. The std. clutch is all metal & you may have some rust from sitting from 1974. Good Luck Larry 2 Quote Link to comment Share on other sites More sharing options...
ukmatador Posted July 21, 2016 Author Report Share Posted July 21, 2016 Yes Larry, ATF did the trick. John 1 Quote Link to comment Share on other sites More sharing options...
sdm Posted July 23, 2016 Report Share Posted July 23, 2016 Always good to hear progress! Sam Quote Link to comment Share on other sites More sharing options...
