Oil Pump And Light
guy53
A friend ask me about taking off the oil pump on is TY ( 493-101 ), no problem just take the front cover off, unscrew the pump and pull the shaft and bushing off install a cover with a gasket: voila! the pump is out ( just block the oil intake at the motor ) I never had one that had a clip inside the clutch cover. Was I just lucky ?
And If I want to replace the standard light with LED any advise ?
Guy
You forgot to mention you need to block off the carb oil feed.
I wouldn't fit an LED bulb, the voltage is not stable and most bulbs that would fit probably are probably not suitable for fluctuating AC.
  • 2 years later...
On 7/21/2016 at 12:42 PM, tony27 said:
"A" model runs oil feed into intake port on barrel like most bikes of the time instead of into the carb like the later models running mikuni carbs Andy
Tony27
  I have the A model 250 1974 I took the oil pump out and blocked off the inlet tube and put in the plate but I'm wondering if the oil in the gas would call for a larger jet because of the thicker gas mixture?
