embrelleur Posted July 26, 2016 Report Share Posted July 26, 2016 I did not find the spec on how much freeplay there should be on the big end bearing? I Quote Link to comment Share on other sites More sharing options...
embrelleur Posted July 26, 2016 Author Report Share Posted July 26, 2016 (edited) ok, I found something, I think I will be on a big rebuild of the engine, piston, rings, overbore, conrod and bearings and find a place to split the crank... Edited July 26, 2016 by embrelleur Quote Link to comment Share on other sites More sharing options...
guy53 Posted July 26, 2016 Report Share Posted July 26, 2016 Do you mean side play ? Guy Quote Link to comment Share on other sites More sharing options...
embrelleur Posted July 26, 2016 Author Report Share Posted July 26, 2016 yes, my bad, side play Quote Link to comment Share on other sites More sharing options...
embrelleur Posted July 26, 2016 Author Report Share Posted July 26, 2016 (edited) Anyway I found the specs and it's ok on the sideplay but not on the axial play, it's a bit over the 2mm max allowed. The small end bearing feels a bit loose too. The piston feels a bit too loose, and the ring end gap is too large. So I'm in for a rebuild It wiull be a winter project. I will need to find a place who splits crankshafts Edited July 26, 2016 by embrelleur Quote Link to comment Share on other sites More sharing options...
