richierich Posted July 30, 2016 Report Share Posted July 30, 2016 I have just sheared one side of the bottom clamp around the right hand fork. It already had a hair line crack for the last 14 months and I knew it would probably fail in the near future and at the most inconvenient time. Can anyone tell me if a 315 clamp would fit from a later model with the rainbow Showa forks? The 4rt Showa forks are 39mm diameter bu I am not sure if those fitted to the 315 (2001 - 2005) are compatible. Alternatively, I know there are various after market top clamps available but could any one recommend someone that makes top and bottom clamps as a pair? Many thanks in anticipation of getting some valuable info. Quote Link to comment Share on other sites More sharing options...
jrsunt Posted July 30, 2016 Report Share Posted July 30, 2016 It should fit, uses the same head bearing sizes and the forks are both 39mm. 1 Quote Link to comment Share on other sites More sharing options...
richierich Posted July 30, 2016 Author Report Share Posted July 30, 2016 That is the answer I was hoping for, jrsunt. Many thanks. Still a rare commodity to find on the second hand market, though, I believe. Quote Link to comment Share on other sites More sharing options...
chris200 Posted August 9, 2016 Report Share Posted August 9, 2016 That is the answer I was hoping for, jrsunt. Many thanks. Still a rare commodity to find on the second hand market, though, I believe. Have you tried ebay ? Quote Link to comment Share on other sites More sharing options...
