dhdey Posted August 13, 2016 Author Report Share Posted August 13, 2016 so the flywheel bolts came llose and sheared and took out coil pickup. anyone know specs? of where to source just a pickup Quote Link to comment Share on other sites More sharing options...
picktas Posted August 13, 2016 Report Share Posted August 13, 2016 Hi dhdey I took my sensor into the local KTM Dealer & replaced sensor with a similar KTM item. I think the resistance of a standard coil is about 150 ohms and the coil I replaced it with was 100 ohms. Main reason for using it was it was correct physical size and mountings were same. Used the uprated bolts from the 2012 onward models (From Trials & Tribulations), just had to use a rose bit drill on the crankcase cover to allow room for the deeper heads on the bolts. Been in the bike (2011 Ossa) for a year now and working well. I thought the bolts were uprated in the 2012 Ian Quote Link to comment Share on other sites More sharing options...
