leepb Posted August 8, 2016 Report Share Posted August 8, 2016 New to trials and gone and got a Beta Evo 290 2T 2006 bike. The left fork seal has started to leak and was wondering if any of you guys or girls know the correct size for the fork seals on this model. Done some searching and can only find sizes for later models. Thanks Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 8, 2016 Report Share Posted August 8, 2016 2006 was called a Rev3. The EVO model started in 2009. Probably why you are having difficulty finding them. Quote Link to comment Share on other sites More sharing options...
reggie Posted August 8, 2016 Report Share Posted August 8, 2016 Same size since 2002 to 2016 , to the best of my memory. Quote Link to comment Share on other sites More sharing options...
leepb Posted August 8, 2016 Author Report Share Posted August 8, 2016 2006 was called a Rev3. The EVO model started in 2009. Probably why you are having difficulty finding them. Thanks Dan, that will be the reason why I am struggling to find them. Quote Link to comment Share on other sites More sharing options...
leepb Posted August 8, 2016 Author Report Share Posted August 8, 2016 Same size since 2002 to 2016 , to the best of my memory. so these will be 38x50x8 seals Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 8, 2016 Report Share Posted August 8, 2016 Yup, there's the standard Beta ones and the new SKF ones that are a little shorter for the dust cap. The SKFs I put in a friend's bike tended to pop the dust cap out of the fork leg until they settled in. You will need a fork seal tool. Easy to make out of a length of PVC pipe. There's lots of information on this forum on changing fork seals. The Paioli forks on your Beta are the same as the forks on the Shercos of the same vintage and there is excellent instruction on those forks if you do a bit of searching. Most disconcerting is taking the fork legs off after the bottom bolt is removed and the circlip above the seal is removed. To pop the seal out and remove the bottom part of the leg you treat it like a slide hammer pulling the slider down from the stanchion tube to pop the seal out. Do this with the fork still in the triple clamps. To seat the seals you remove the stanchion from the triple clamp, slide the seals onto the stanchion and insert the stanchion into the slider, replace the bolt on the bottom of the slide, slide the seal tool/PVC pipe over the stanchion and give a few good taps on top of the seal tool to seat the seal into the fork leg. Replace the circlip on top of the seal and repeat the process with the dust cap. I cut a chamfer into the PVC pipe so it doesn't chew up the seal lips. I also noticed on the SKF seals the chamfer needed to be deeper as the SKF dust caps have a more pronounced lip. I think the PVC pipe I made the seal tool out of was 1 3/8 but I'll have to check as it's out in the garage. 1 Quote Link to comment Share on other sites More sharing options...
dan williams Posted August 9, 2016 Report Share Posted August 9, 2016 (edited) The plastic fork seal tools are actually 1 5/8 inner diameter and 18 inches long. Comes in handy 10 ft lengths. Edited August 9, 2016 by dan williams Quote Link to comment Share on other sites More sharing options...
leepb Posted August 9, 2016 Author Report Share Posted August 9, 2016 The plastic fork seal tools are actually 1 5/8 inner diameter and 18 inches long. Comes in handy 10 ft lengths. Thanks again Dan, done fork seals before but good to know about the pipe seal tool Quote Link to comment Share on other sites More sharing options...
