gazzaecowarrior Posted August 10, 2016 Report Share Posted August 10, 2016 Just removed my carb for a strip and rebuild on my 08 250 txt pro. Its got an overflow / breather pipe in the choke side about 2" long. On the other side is a spiggot which looks like a pipe should be on it but there isn't. Should there be a pipe or not. I'm worried water etc could enter the carb if the pipe isn't on the other side. Any ideas ? Quote Link to comment Share on other sites More sharing options...
copemech Posted August 11, 2016 Report Share Posted August 11, 2016 Should have a 90 degree outlet on both sides, and a short tube like that does make a good crap deflector when washing and such on both. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted August 11, 2016 Author Report Share Posted August 11, 2016 Should have a 90 degree outlet on both sides, and a short tube like that does make a good crap deflector when washing and such on both. Thanks for that. I thought it was missing something. Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted August 11, 2016 Report Share Posted August 11, 2016 I have got one tube to both sides, with a large cut on the bottom Quote Link to comment Share on other sites More sharing options...
richt Posted August 11, 2016 Report Share Posted August 11, 2016 If you use a single pipe to join both sides it must have hole at the bottom. Quote Link to comment Share on other sites More sharing options...
gazzaecowarrior Posted August 11, 2016 Author Report Share Posted August 11, 2016 Thanks for all the responses. I'll do two single pipes. Are they breather or overflow pipes ? Quote Link to comment Share on other sites More sharing options...
crazybond700 Posted August 12, 2016 Report Share Posted August 12, 2016 (edited) If you use a single pipe to join both sides it must have hole at the bottom. Yeah, I cut out a sort of diamond shape on the bottom of the tube. Easily done with cut pliers Edited August 12, 2016 by crazybond700 Quote Link to comment Share on other sites More sharing options...
copemech Posted August 15, 2016 Report Share Posted August 15, 2016 They are breathers but fuel can spill if the bike it on its side. Quote Link to comment Share on other sites More sharing options...
